Smoked headlight DIY high beam question
  • quikveedb2
    • Sep 2007
    • 2258
    Hi guys, I'm working on smoking my high beams & I've run into an issue. I popped the lens off and the refective coating seems to have worn off, revealing the color of the plastic underneath. Sadly, the reflector also melted just a bit in the oven, but the melted area is small, and barely shows with the cross hair and lens in place. However, the brown plastic does show, and kind of bothers me. Also, both probably are going to affect performance. So, before I put this all back together and end up with a subpar final product does anyone have suggestions on how to fix the missing reflective coating?
    You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
  • AndrewBird
    The Mad Scientist
    • 11897
    That reflector is toast. Nothing you can do about it I'm afraid. I'd find a different one.
    • quikveedb2
      • Sep 2007
      • 2258
      Fml. That's kinda what I figured.
      • rcsoundn1
        • Nov 2012
        • 3361
        chrome paint?
        • Das Delfin
          • Sep 2014
          • 2293
          ^ I was going to suggest the same. This is the best I've found
          • AndrewBird
            The Mad Scientist
            • 11897
            Won't be nearly good enough. Just get a new reflector.
