Ellipsoid problems
  • dmb62
    • Oct 2015
    • 42
    Ellipsoid problems
    Wired in my ellipsoids everything works but now whenever I turn on my high beams the blue light on the dash to indicate high beams are on no longer works. Anybody know how to do. This car is 87 eta
  • Das Delfin
    • Sep 2014
    • 2293
    Take out cluster and test bulb
    • dmb62
      • Oct 2015
      • 42
      Il try that but it was working right before I had to bypass the high beam low beam relay could that be the problem?
      • Das Delfin
        • Sep 2014
        • 2293
        No, the indicator bulb is on the same circuit as one of the high beam fuses. So as long as both your high beams are working you should be good
