Is it possible to separate the lens from an early tail?
  • nrubenstein
    • 3148
    I have a perfect lens on an early tail, but the chrome inside has corroded badly. It it possible to separate them? If so, any tips?
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • Mo Brighta
    • 433
    reflector badness
    These lenses are not made to come apart; the silvering is a coating, not chrome plating, more of a silver paint.
    Before you toss it, try giving it a good hot bath with soapy water, like a dish soap. You put a smallish rag inside the reflector through the bulb opening, then fill with hot soapy water and swish it around, and use your finger to gently rub the dish with the rag. This may turn out to be dirt and crap like exhaust buildup and such. The bath may clean it all up and you've saved a lens.
    Good luck.
    Andy says "Be Seen, and Not Hurt!"
    Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
    Tail Light Improvements keep them off your tail.
    Headlight protection saves headlights from breakage.
    • RobTapps88
      • Feb 2017
      • 137
      Poo I was wondering the same.. PO sprayed the tails flat black and some got under the edge of the lens now it looks gross after I removed all the paint from the outside surface
      Sent from my LG-H831 using Tapatalk
