Bought an e30 With Depo Smileys; Can I Save These?
  • gilber33
    • Jul 2012
    • 244
    So, as I rebuild my e30, one thing that I needed to look at are the headlights. The PO wired up HIDs and I'm not a fan of those so I wanted to pull those out and put in standard bulbs. After looking at pictures of these lights and some of the wiring DIYs I'm afraid I may have an issue.
    So, first things first it looks like I'm missing the caps on the back of the low beams. Second, it appears the plugs wired in are specific to the HID ballast or whatever it's called. Am i correct? And third, the bulb mounting on the high beam on the driver side looks screwed.
    I guess I'm looking for some guidance on what to do. It seems if I keep these or get stock lights, i need different plugs from the car. But since I'm missing the caps on the low beams and the high beam retainer is messed up, I'm not sure I can reuse these lights.
