Fog light bulb recommendations?
  • silversleeper
    • Mar 2005
    • 2032
    I want to run the highest wattage safely in my fogs... I don't feel like buying an HID kit for them. But I am more wondering where I should buy them... some place that is reputable and has good options of quality higher wattage bulbs to choose from.
    Claus Luthe is my hero.
  • LINUS
    • 2422
    H3, right? The possibilities are endless, but really I'd stick to a good basic cheap bulb, since the fogs see so much abuse as low as they sit. At least I seem to blow a bulb at least once a year. I wouldn't buy anything too fancy or anything that only comes in pairs. I have basic 100 watt Hella brand H3's that I get at the local Piston Service for like $6.50 each.
    It's not how you handle the good times, but the faith you keep in the bad that defines you.
    • silversleeper
      • Mar 2005
      • 2032
      My local WalMart is probably the cheapest place around here, and they have the lowest level Sylvanias going for $10 each. No shops that I know of carry Hella either. I wanted some nice Osram bulbs, higher wattage preferred. I have to check my 89 E30, because I believe some cars have H3 and some have H1. I dunno if that is the difference between a facelifted E30 and earlier ones. So I'm looking for a website that carries the kind I am looking for.
      • LINUS
        • 2422
        Only reason I assumed H3 is that M3 fogs are that. I haven't ever had my mitts on any other. I just keep an extra H3 around since the H3's also fit the driver light side of my Piaa XT90's on my Landcruiser.
