100watt H3 bulbs in my fog lights?
  • OSM e30
    • Jan 2007
    • 55
    i was wondering if 100w h3 bulbs will work fine for my foglights on my 89 e30, or will it melt the wires? whats the worst that can happen?
  • NC325iC
    • Mar 2004
    • 6565
    dont think itd melt wires maybe the melt the housing though
    • rede30
      • 4697
      Yea its a bad idea. It will work well for a short while but you will melt stuff and it wont be worth the little bit of brightness that you gained.
      • Mike325
        • Mar 2006
        • 3685
        Yep
        Originally posted by Kershaw
        • OSM e30
          • Jan 2007
          • 55
          whats the highest wattage bulb u think i can put in?
          • MrK
            • Jan 2006
            • 709
            I installed 100w hella h3s into my foglight housings. Nothing melted, but they went out in a matter of days, so it's not worth it.
            This is your M20 on steroids:
            • NC325iC
              • Mar 2004
              • 6565
              just stick with good 55w bulbs
              • Mike325
                • Mar 2006
                • 3685
                Like silverstars.
                • MOTOREN
                  • Oct 2006
                  • 34
                  hmmmm...I went with 100-watts and stuff melted for about 15 min then they were fine to be honest
                  :roll:
                  • golde30
                    • 11464
                    must have been the POWA of yer m3 grill badge!!!!!!!!11111ELEVEN
                    IG: @Baye30
                    • LINUS
                      • 2422
                      Ouch!
                      -That badge is kinda lame, unless you are packing a S code engine, and so far I haven't heard of an IX swapped yet.
                      Put the badge on yer toolbox, it'll look just as cool and you won't catch isht from other BMW guys.
                      It's not how you handle the good times, but the faith you keep in the bad that defines you.
                      • mtechnik
                        • 6156
                        If BMW knew the trouble this issue caused they prolly wouldn't have made these badges available. Then again the company doesn't to care what a large cross section of loyal Bimmer fahrers think.
