My drivers side fog is not working. I replaced the bulb because I thought that was the problem, the light is still off and I am not sure how to go about fixing it or even what to check. The passenger side is still working. Thanks
Broken Fog
Check for power at the connector. Is your connector dirty? If there is no power there and it is clean, trace the wires back and see if it is cut anywhere.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
Originally posted by Jbpka06 View Posttime to go buy a multimeterOriginally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
Use an ohm meter and put one lead to another pin on the connector (dunno which is ground, prolly brown wire) and the other lead on a ground (i.e. strut tower)
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.
