Smoked front fogs?
  • eko
    • Mar 2006
    • 372
    Smoked front fogs?
    Has anyone smoked there early front fogs?
    Going to have a go at doing mine to match the headlights.
    Was going to try and make some Xhairs to do it.
    Anyone got a template?
    94 316i Touring M52B28
    Made in Germany perfected in Britain!
  • eko
    • Mar 2006
    • 372
    Anyone?
    • eko
      • Mar 2006
      • 372
      Surely one of you guys has done this?
      • e30_325es
        • 1249
        LaminX
        • eko
          • Mar 2006
          • 372
          Originally posted by e30_325es
          LaminX
          Not available in the UK although i suppose there is an alternative?
          This will restrict light though right?
          Ok,i never really use the fogs but may as well try and do it right!
          Someone on the E30zone suggested i try and use some fine mesh sprayed black and stuck inside the lens,may look into doing this?
          • eko
            • Mar 2006
            • 372
            Originally posted by eko
            Right gave the above method a go!
            Managed to find half a tin of Satin Black in my shed.
            Gave the metal a couple of coats after a coat of primer.
            Then hot glued them inside the lense.
            Then using the same Black sealant that i used for my headlights(lasted 6 months so far with no leaking) i bonded the lenses back on.
            Took the following pictures along the way,although not the best.
            End result actually looks better than the picture shows but proof will be when i refit them to the car tomorrow,ill update the pics then.
            Anyway let me know what you think.
            If you think they look shite then say so :D
            • E30 Reaktionär
              Site Manager
              • 14451
              got any pictures of them mounted in your car?
              1992 BMW 325iC
              1978 Chevrolet Monte Carlo
              • T.Dot_E30
                • Mar 2004
                • 286
                that probably restricts more light than laminX would.
                • eko
                  • Mar 2006
                  • 372
                  But where is the fun in cutting laminX.
                  Rather put the effort in and have a go at modifying,so much more satisfaction:D
                  • eko
                    • Mar 2006
                    • 372
                    Pics here of them fitted!
                    • T.Dot_E30
                      • Mar 2004
                      • 286
                      Oh well in that case you shoulda put the effort and made some cross-hairs and have more light :D
