Low beams not working???
  • e30ryan///m3
    • Dec 2005
    • 249
    Hi Everyone,
    My low beams aren't working! I have high beams but no low beams. Could it be the relay? and which relay controls the low beams. I've checked the fuses for each low beam and they are fine. I feel it is the relay but I don't know which one controls the low beams. Thanks for any help.
    Ryan
    1988 M3 (Diamondshwartz)
    2004 M3 (SilverGray)
  • kommissar
    • Dec 2005
    • 402
    Here is the layout. Hope this helps you diagnose your problem.
    • e30ryan///m3
      • Dec 2005
      • 249
      Thanks that is just what I was looking for
      • ivo316
        • Oct 2006
        • 1222
        On mine, the position lights worked, so did the high beams, but the low beams did not work, it ended being corroded ground leads in the bulb sockets.
        • e30ryan///m3
          • Dec 2005
          • 249
          Yeah,
          My parking lights work and the high beams work but the low beams aren't working! I will check the grounds in the bulb sockets and the low beam relay. Hopefully that fixes it, otherwise I have no clue!
          • ivo316
            • Oct 2006
            • 1222
            you got PM. ;)
