why am i blowing fuses.
  • eyagel
    • Jan 2007
    • 756
    i have an "e" with an "i" front lip on it and it has foglights that are connected through the factory switch..so the other day i go to turn on my fogs and nothing happens..**fuse** i say to myself..so i get home and change the 7.5 fuse and go to test it out and blows the fuse again..so i try it again with a 7.5....blown again...
    why is this happening..
    --eric
  • AndrewBird
    The Mad Scientist
    • 11898
    Are you sure 7.5A is the right fuse? Seems kind of small for fog lights, hence the blowing.
    Check your wiring. If the fuse is correct, there must be a short somewhere.
    • eyagel
      • Jan 2007
      • 756
      it says 7.5 in the book..but that is for the stock fogs..and i dono if the "e"(bumper mounted fogs) and the "i" (valence mounted fogs) are the same size, power, etc.
      • Teaguer
        • Sep 2004
        • 6167
        Theres no fog in Houston . Keep them off .
          • 37833
          Trace the wires, I bet something is grounding out somewhere.
          Grover Beach, California
          BimmerHeads.com
          • backtrail69
            • Jul 2005
            • 4471
            Do you have the wrong wattage of bulbs in there?
            :: PNW Crew ::
            '87 325 4dr, '74 2002
            • eyagel
              • Jan 2007
              • 756
              no they worked before..then all of the sudden they started blowing..??!?!!
              • atomic
                • Jun 2007
                • 5691
                You might want to check the power lead wire that is on the back side of the h3 bulb. There might be a chance that it is shorting out on the metal housing that the bulbs clips into as well. Or there is a short somewhere else if you are not running higher wattage bulbs which would blow the fuse that the factory recommends...
