elipsoid swap
  • colombacho
    • May 2007
    • 391
    elipsoid swap
    I have been looking and searching all over the lighting section and cant figure it out. And i am not sure what i am doing. already burned more than seven fused connecting everything to everyting with no luck.
    My sealed beams have three connections
    pass side:
    1 Ground= brown
    2 current= white/blue
    3 misterious 3rd wire that has no current runing through= yellow/white
    Drivers side:
    1 Ground = brown
    2 current = white/purple
    3 same stupid third wire tha f's up everyting=yellow/white
    Elipsoids with two connections(9006 i think)
    left and right
    1 Ground
    2 current
    the big problem i have is that my low beams do not turn on. only when i turn my highs they turn on. I also checked for current and there is current but the light does not turn on.
    Am i supposed to do something with this EFFING! THIRD CABLE!!:curse:
    Any help appreciated:D
  • JasonC
    Site Manager
    • 14451
    Thumb though this thread, http://www.r3vlimited.com/board/showthread.php?t=59735 You shouild find what you're looking for.
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
    • colombacho
      • May 2007
      • 391
      Mmmm, it better not be that simple.
      I'll try it tonight.
      • golde30
        • 11464
        yah, you are using the wrong wire for + on the low beams.
        IG: @Baye30
        • colombacho
          • May 2007
          • 391
          thanks alot guys, the other wire was not working because i had already blown the fuse. Got it good now. just a tipical @sshole mistake.
          • Boomerang
            • Feb 2007
            • 224
            thanks guys, i was going to make a topic until i came across this one, very informative.
