independant fogs
  • rayz
    • 494
    independant fogs
    everything with my fuse/relay matched up with what was on the article on BEN. but it did not werk. I connected pin 87 and 30, put the fuse/relay back in and my headlights came on. (without the key in the ignition). I then tried connecting 87 to the pin on the opposite side. i think 85. put the fuse/relay back in, put the key into acc, and the the fuse/relay buzzed. everything werked normally tho. just a loud buzz.
    anyone here complete this mod? why isnt mine? the fuse location and pin location is just as described in the tech article. my car is a '90.
    TIA
    Ray
    FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
  • bimmerphile
    • 3495
    This mod needs to be done different for every model E30. The article on BEN only works on some cars.
    If you want to get it to work, you'll need to do it like Nick Majka: http://www.mmsport.s5.com/foglights.html
    I have a writeup for how to do it to 88/89 cars, but my writeup will ONLY work with US ellipsoid cars.
    • OOMPH!
      • 3487
      This one might work....
      • e304lyfe
        • 807
        relay thing dont work in my car eithor..... an '89. i have given up, not worth the aggrevation.
        • golde30
          • 11464
          yeah, i tried to wire my 88 like my frends 89 and i got a wierd reaction. when i did the 87 to 30 connection i was able to turn on the fog lights with the key out of the ignition, but only at the second click on the switch...BUST...so then i decided to take out my frends modded relay and put it in my car...thats when i got a super wierd result...what happened was that the fogs would turn on with the first click, but when you turn off the lights, the fogs would stay on by thenselves??? the only way to turn off the fogs was to turn off the actual fog light switch, but the fogs couldnt be turned on without first turning on the headlight switch to the first click...this was with the modded relay out of an 89...any1 have any ideas on this one?
          IG: @Baye30
          • NC325iC
            • Mar 2004
            • 6565
            anyone know a way to make it so the parking lights turn off with the car
            • Rob
              • 8166
              ---> Appearance/cosmetic
              BEERTECH
              • e30Matt
                • 5077
                I know Franz's mod works on sealed beam cars... did it on mine. You just bridge two pins on the foglight relay with a jumper wire.
                • bimmerphile
                  • 3495
                  No, it doesn't. That's jsut what he said he did, and it didn't work.
                  When I say there's a good 5 different ways, I mean there's a good 5 different ways.
                  -Kris
                  grumpy today
                  • e30Matt
                    • 5077
                    It doesn't?
                    • bimmerphile
                      • 3495
                      It doesn't?
                      I meant that it doesn't work on his (because that's what he tried).
                      I don't doubt that it worked for you.
                      • Rob
                        • 8166
                        I used aluminum foil
                        BEERTECH
                        • rayz
                          • 494
                          thanks everyone. ill see what works and let you all know. i think the one from thurbers might werk..
                          • rayz
                            • 494
                            i give up for now. atleast till i can get extra relays to mess with. ill keep u posted.
                            • Inspar8r
                              • 301
                              10 bucks says your car is at least a 88 model....
                              Nick
                              87 325 5MT
                              02 IS300 5MT
