how did you guys cut your crosshairs?
  • scobaru
    • Nov 2007
    • 396
    I have a sheet of metal that I'm going to cut for crosshairs.... what would be the best method to do this?
  • Jordan
    • 12913
    If you use thin steel or aluminum... sharp stainless scissors will work fine. If its thicker steel... then tin snips.
    https://mtechniqueabs.com/
    • Van Westervelt
      • 9365
      dremel too or a die grinder works. depends on how steady of a hand you have tho. lol
      • scobaru
        • Nov 2007
        • 396
        you use the rotating cutting wheel for a dremal? I'm using some semi thick aluminum
        • e30pwr
          • Oct 2007
          • 642
          Numbers?
          • ToplessE30
            • 4791
            Tin snips then get the intricate stuff with the dremel.
            Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
            • Sean5294
              • Jan 2008
              • 515
              the dremel is king, just watch out for the cutting wheel breaking and hitting you in the face!
              • turbogeek
                • Oct 2007
                • 10
                assuming you already have the stencil pattern yes?
