Fog light lense repacement
  • naplesE30
    • Nov 2007
    • 1839
    I am getting ready to but some replacement lenses from www.bmwlight.com for my elips fog lights. The lenses bmwlight sells are plastic. Has anyone used these, if so what are your opinions? Is there anyone that sells glass lenses that you know of?
  • redhatpat
    • Aug 2005
    • 656
    At least make a token effort at finding this info. This has been covered, a few times.
    • naplesE30
      • Nov 2007
      • 1839
      Well I purchased the bmwlight plastic lenses so we will see how they turn out... Have to be better then they are now
      • dlmrun2002
        • Apr 2007
        • 808
        Lens replacement
        I used them... Getting the old glass lenses out is a little work. Not too bad--just be patient. You can try a heat gun to soften up the old glue. Be careful not to melt the housing. Also a sharp knife to get in there and help cut the seal. Careful again of light housing and digits. One write up said use clear silicone for attaching the lens. I used it but wish I had used black instead. Your choice..
        hth.
        DLM.......my dog Skye gave me wings to fly
        • n2motorsports
          • Jun 2007
          • 173
          can you go into more detail about this? I have a set on the way. Thanks.
          • naplesE30
            • Nov 2007
            • 1839
            I found a good write up on e30tech. Would skip the breaking glass lense though. http://www.e30tech.com/forum/showthread.php?t=47457
