Hella H4 Review
  • Jean
    • 18228
    Hella H4 Review
    For the longest time I was wondering just how good the Hella H4 lights could be. Well, I took the time to take a couple pictures back to back against the Sealed beams.
    The bulbs I am using are 100 watt bulbs.
    First, this is what the look like when you compare them to your regular $10 sealed beams.
    The H4 headlights (high/low) sell for about $90 for a pair http://www.rallylights.com/hella/5.75_lo.asp
    To install them all you have to do is remove the 3 small screws on outside metal trim ring that holds the sealed beam in the headlight frame bucket.
    Here is shot of what the output looks like against a sealed beam output. Sealed beam on the left, H4 on the right.
    Here is shot with both H4 lights installed.
    H4 light output on the road. I adjusted the height to make sure not to blind other drivers and took the car for a spin.
    Not a single car flashed their lights at me.
    I've had US Ellipsoids on my car with new Silverstar bulbs and I was never impressed with them. I can 100% say that the Hella H4 buckets provide much better output than a good set of Ellipsoids.
    If someone wants to let me borrow their Ellipsoids + HID I will then compare it back to back again if there is interest :)
    Hopefully this was helpful to some.
  • ///M42 sport
    • 3952
    thnks for writeup
    • Jean
      • 18228
      Few guys mentioned that the pattern doesn't look like the H4 pattern. So, I am going to double check my installation / wiring and update this thread again.
      Thanks
      • hendrixvodu
        • Jan 2007
        • 2514
        i have to agree with you jean.....the projectors suck compared to H4's IMO
        -His-
        87 e30 325i
        87 e24 m6
        05 e83 x3
        94 e32 740i 5spd
        -Hers-
        89 e30 325i
        18 f48 x1
        • Mike B.
          • Jan 2006
          • 987
          The Hella's are very, very nice, but you should see the Cibie' CSR's - Unbelievable!! Their price also reflects this fact.
          • Jean
            • 18228
            I appologize, I had them wired on Highs instead of Lows.
            Here is correct output pattern .
            • Mike B.
              • Jan 2006
              • 987
              That looks more like it... Notice the sharp cutoff.
              • FredK
                • 14761
                Yeah, I've always wanted to jump on a set of Cibie CSRs, but they're rather expensive. Still, I think they're around the same price as a set of Hella smoked ellipsoids.
                • Mike B.
                  • Jan 2006
                  • 987
                  A set of CSR's will run a bit over $400 from Daniel Stern.
                  • N2MYE30
                    • Oct 2007
                    • 5536
                    This was the first upgrade I did for my car 2+ years ago..and still wouldn't trade them in for nuttin. I put some PIAA super whites in when I got them too. Its a huge difference from the candles it came with. Once one of those PIAAs go, HIDs, here i come. But Im getting my moneys worth outta my PIAAs.
                    Oh, I paid $80 for the hellas back then and maybe $65 for the bulbs.
                    COTM
