LED Front Turns/Running Lights
  • Schnitzer318is
    • Jan 2008
    • 2057
    Yes I love LEDs... it's a well known fact. I think I've outdone myself with these though. 60 5mm 10000mcd LED's per side. Looks MEGA hawtness and are super bright at night but definitely bright enough to be seen easily during the day. What do you guys think? BTW I'm ordering a better smoked MHW lens from Abraham's... the lenses pictured are the crappy depo smoked fuc$ers. They suck and scatter the light instead of focusing it forward..
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
  • StereoInstaller1
    GAS
    • 22679
    Damn, man, excellent work.
    Are you "potting" these?
    Closing SOON!
    Thanks for 10 years of fun!
    • 2002maniac
      • 4260
      you're crazy. too much time on your hands ;)
      • Hartge_H27
        • Jun 2006
        • 1699
        looks good. so when r u going to start selling these.
        • Schnitzer318is
          • Jan 2008
          • 2057
          Thanks guys for all the compliments. I could make these fairly easily if anyone is interested, they just take awhile to do. LOL soldering that many LED's sucks let me tell you. I can post a diagram of the wiring with resistor value and lead orientations, but no writeup. It's fairly easy if you know how to or are willing to learn how to solder.
          91 318is Turbo Sold
          06 4.8is X5
          06 Mtec X3
          05 4.4i X5 Sold
          90 325i Sold
          97 328is Sold
          01 323ci Sold
          92 325i Sold
          83 528e Totaled
          98 328i Sold
          93 325i Sold
          • BeirBrennerE30
            • 2740
            nice! more day and night shots?
            e30sport.net
            '06 M3 Competition - 6-speed
            '97 Range Rover Vitesse
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              I'm interested if you are potting them too in order to eliminate any moisture intrusion.
              How do you get them to blink?
              In conjunction with that, how do you get them NOT to blink twice as fast? Did you mimic the resistance of the bulb to "trick" the system into thinking that a bulb was there?
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
              • Schnitzer318is
                • Jan 2008
                • 2057
                They aren't potted yet but I may do that. I've already driven through a pretty good thunderstorm and washed my car a couple of times as well with no issue. I usually just use hot glue for my weather proofing needs, but I haven't had an issue yet.
                As for the hyperblink... I have a 318is so I don't have a check computer. Makes it easier for me. Each array uses 4-5watts if I remember correctly, not sure if that is enough to disable hyperblink. But I avoided all that by using a relay on each side so that I was able to get parking and signal functions to the LEDs. I have an ambulance LED controller that I could use to actually use dim for the parking lights and bright for the signal lights, but I kind of like them being bright all the time. I may use the ambulance one just for the tail lights, or not at all. On the dim setting the LEDs are kind of hard to see during the day.
                91 318is Turbo Sold
                06 4.8is X5
                06 Mtec X3
                05 4.4i X5 Sold
                90 325i Sold
                97 328is Sold
                01 323ci Sold
                92 325i Sold
                83 528e Totaled
                98 328i Sold
                93 325i Sold
                • StereoInstaller1
                  GAS
                  • 22679
                  I wish to hell the sequential controller that I want for the tails would get back in stock.
                  I am thinking epoxy for potting would make the damn things bullet proof, but serviceability would then be 100% gone.
                  I sure do like the look of those turns, man...very nice.
                  Closing SOON!
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    This stuff is your friend:
                    http://www.tapecase.com/p.9.5/3m-dp2...-compound.aspx
                    You could just hook a resistor in series withe each array to dim them. You would have to play around and test what resistance value would work best. And they would have to be high wattage ceramic resistors.
                    • Schnitzer318is
                      • Jan 2008
                      • 2057
                      ^Ya but like Luke said, serviceability is toast after that. Have to make a new array if a chain or LED went out. I'm going to run mine without anything first just to see if it's fine like that. So far so good... and I'd really like to just be able to solder a new LED in if one ever went out on me in a couple of years (I drive with lights on all the time).
                      Thanks for the compliments Luke, you should definitely do it. It's one of my favorite things on the car right now. BTW which sequential controller you talking about? Wouldn't a mustang one work?
                      Dimming isn't an issue, I bought a ShoMe ambulance LED controller that does all the work for me (even has wig wag output if I want). I just haven't hooked it up to an array yet to see how dim the parking light setting really is. I just think I like the lights bright all the time like they are now and then turn on and off with signals instead of bright dim with the ShowMe controller. I'll probably hook it up just to see it in action and make my decision then.
                      91 318is Turbo Sold
                      06 4.8is X5
                      06 Mtec X3
                      05 4.4i X5 Sold
                      90 325i Sold
                      97 328is Sold
                      01 323ci Sold
                      92 325i Sold
                      83 528e Totaled
                      98 328i Sold
                      93 325i Sold
                      • StereoInstaller1
                        GAS
                        • 22679
                        The sequential controller I want to use is 100% electronic, and resets to "zero" if shut off mid-blink.
                        I get them from one of my stereo junk suppliers, just one I rarely use, because they are always out of stock on crap...like this part I need.
                        I wonder if any LEDs are more reliable than others, like maybe Panasonic?
                        Closing SOON!
                        • Schnitzer318is
                          • Jan 2008
                          • 2057
                          Not sure about reliability. I have mine running at 60% of rated input (20ma rated) so they should last damn near forever barring weather intrusion. They are just the cheap hong kong mass produced jobs, I forget the manufacturers name. I could get them brighter if I wanted to feed them more power, but I'm pretty happy with where they are now. Maybe I'll up it (lower resistor value) if I use that ambulance controller's dim and bright functions for the signals.
                          I'm sure higher quality LEDs have more consistent color/quantity of light output from run to run, but life cycle on most LEDs is rated at 100,000 hours from what I've been able to find.
                          91 318is Turbo Sold
                          06 4.8is X5
                          06 Mtec X3
                          05 4.4i X5 Sold
                          90 325i Sold
                          97 328is Sold
                          01 323ci Sold
                          92 325i Sold
                          83 528e Totaled
                          98 328i Sold
                          93 325i Sold
                          • Larry e30
                            • 182
                            Thats awesome, I'd be willing to buy some of these, when you turn your headlights on are they dimmer than when you activate the turn signal?
                            • Schnitzer318is
                              • Jan 2008
                              • 2057
                              Not right now no. They are on full brightness all the time with the headlights on... then when you activate the turn signal they blink on and off at full brightness. I am thinking about wiring a controller to it to do the dimming function but haven't decided on that yet. I kind of like full brightness all the time since I drive with my headlights on during the day most of the time.
                              I'll post in here if I decide to start selling them, but it takes awhile to solder all those LEDs :) Also for the DIY'ers out there I can easily put a diagram up if you want to give it a go.
                              91 318is Turbo Sold
                              06 4.8is X5
                              06 Mtec X3
                              05 4.4i X5 Sold
                              90 325i Sold
                              97 328is Sold
                              01 323ci Sold
                              92 325i Sold
                              83 528e Totaled
                              98 328i Sold
                              93 325i Sold
