I searched here and e30tech with a few combinations of keywords and could only turn up a hyperblnk type of bulb out warning. I'm doing a complete LED rear tail conversion and need some clarification on how our car's lighting works. I did the rear signal with 96 amber LEDs (looks great btw). Everything works properly as it should without a regular bulb in the turn signal spot on the rear bulb carrier. No hyperblnk or anything. As soon as I turn on parking lights or headlights my right turn signal indicator in the cluster illuminates solid and stays lit... and none of the right side signal lights will work properly. If I turn parking lights/headlights off everything works normally again. Now if I put an incandescent in the bulb socket on the carrier everything works fine with the headlights on. Is this a resistance issue? Should I be looking for some sort of electronic flasher to replace the stocker? (EDIT: As a test I removed the flasher unit altogether and as soon as I turn on the headlight/parking lights the right side turn indicator comes on constant, so I'm not sure a relay will fix this issue.) Or is this related to my LED front turn/parking and LED sidemarker conversion? Perhaps if you have no bulbs on a side (front or back) the indicator will not hyperblink but stay on constant to indicate both bulbs have failed? I'm sure this is just the first hurdle with the LED conversion... but hopefully someone here can help out. TIA
BTW I have some questions about the rear check relay as well for when I get to converting the brake lights and parking lights in the tails. But that's another thread.
