^That would be cool for passing e46, and e36 ers. Though I did own multiple e36's and one e46, my e30 4 banger is the most fun of all 5 bimmers I've had.
E30 LED Tail Lights... (Pics & Vid, 56k no)
"A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold -
very cool. maybe you could display longhorns in orange with a switch?
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFTComment
You can simply go to your local auto parts store to find an electronic flasher.
Hell, I don't even know if E30s use 2 or 3 prong flashers, or some bizarre German monstrosity.
Damn, that is just so cool, get it done!Comment
I put an electronic flasher in it... that's why I have no hyper blink :) And I found the problem... I guess the resistance of the 12ohm 25watt resistor isn't enough to emulate the 12v/10watt bulb that was in the parking light circuit. As soon as I put the original parking light bulb back in the holder everything worked 100%. Soooooo... tomorrow I am going to go get a 10ohm 10watt resistor and see if that will do it. If not I'll keep guessing the resistor needed to trick the circuit. Davesmed is helping on a way around the check circuits altogether but for now I want to get everything working and then work on re wiring the car :)"A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i SoldComment
Right there is my whole bitch with the LED stuff. I want part of my check panel, like the fluid levels and stuff.
I like the idea of losing the check panel alltogether, and having bare LEDs on the dash.Comment
^Why don't you just desolder the LEDs for the lighting system on your check panel? Then you get to keep all your other systems. That's what I would do if I had the overhead check panel.
Here is a new video on the car. I am fairly pleased with the result although I am still going to change some things up. Will keep you guys updated.
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i SoldComment
lovemy318
pretty cute. why didnt you just bake off the tail lights? stick the whole assembly in the oven on 200 then carefully remove with gloves. i did it when tinting my lenses with black die.
also, imo you should even out the led count. seems you have too few in the brake light area.
i might attempt this. i was thinkin of turning my 3rd brake light into a digital (red) display that shows diferent displays n such when signaling foe ex. when i hit my left signal the display should show an arrow moving across like
or when i stop it shows the BMW roundel
or when im turning right it shows
a friend of mines has one on a potiac sunfire. pretty cool. too bad its on a sunfire
you can sutomise it to do anything like up to 5 different displays or effects. his says his name when he starts the car, it reads / !BEEP! \ when he hits the horn. and says stop when he stops and of course the signals. do you guys know if its legal? if not im shellin out the $200 bux for it. its awesome.
oh and if youre wondering how it works, it recieves voltage from 5 diff remote wires and has one power and ground wire. its pregramed via usb by a program called DIGISLPAY and can display 3 seconds of motion pictureComment
Good to know... I didn't think I could bake these apart. I'll have to try that on the second light as it could potentially make things alot easier.
As for the LED count... I'm pretty happy with it, I wanted the brake light section to look different than the parking light section... so I used 2 different types of LEDs. Wide angle high power flux LEDs (24) for the parking lights, and narrow angle 8mm LEDs (36) for the brakes. Super distinct, even in the daytime. Only thing I am not 100% satisfied on yet is the signal viewability during the day. I think this is due to the painted lens. Going to remove the paint and see how it looks then."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i SoldComment
