I need help getting my reverse light to work guys. I checked the fuse and the wiring under the shift boot. Both are still good. Also the bulbs are not burnt. I had the reverse light working when I got the car. Took the center console to clean the carpet and when put back the reverse doesn't work. All the other lights work. (turn signal, brake, park) Its a bi*** backing up at night, help a brother out! TIA!
Problem with reverse light
Reverse light switch.'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
The reverse light switch. It's cheap and easy to replace and it's probably old anyway. Just replace it and if that doesn't fix it then start looking elsewhere. A good rule of thumb is to start easy and cheap and work your way up from there,'89 325is S50 Track Montser
Pull your shifter boot and test the wires there.
Me thinks the 2 wires indicates that the power lead is +12V.Comment
Guess I'll do that first! Can you replace the switch inside the car? Or you have to get under it?
It's threaded into the side of the tranny so you'll need to be under the car. I believe it's a 22mm socket or so, and be sure to replace the sealing ring also! Once you get under the car it should take about 5 minutes.'89 325is S50 Track Montser
Si Senor.'89 325is S50 Track Montser
