brake lights!
  • aSpecD_
    • Jul 2008
    • 495
    brake lights!
    my brake light warning on the check panel lit up. so as soon as i pulled over, i checked the bulbs if any of them were out, nope, took them out and reseat them on the bulb holder.. all rear lights work except for the brakes.. so i checked the fusebox, fuse 6 and 10 were fine. so just for reassurance i bought new bulbs for the brake lights and rear lights. still nothing. the center light also was not working, but i havent gotten there and checked if that bulb was out.. would that break the circuitry and cause the brake lights to not work?
    .. would i need to take out the whole rear parcel shelf to access the bulb on the center light?
    .. once i have replaced the bulb where should i start checking for faults?
    all help would be greatly appreciated.
    i need it fixed asap. i have a night class tomorrow.
    -jeff
    best modification to any car is a clean car.
    -jeff
  • aSpecD_
    • Jul 2008
    • 495
    so after a few searches, i found this:
    so i went under there and found the brake switch.
    it's too bad the dealer is closed on sundays so i cant get the switch today.
    anyway. i discovered this mysterious oily greenish liquid that wet my floormat, and the leak marks seem to be coming from next to the foot vent/blower. i dont see the droplets happening but there's a trail of it on the carpet. does anyone know what it is or where it is coming from?
    -jeff
    • Sam Cogley
      • Jun 2008
      • 521
      Sounds like your heater coolant lines or the core are leaking.
      • aSpecD_
        • Jul 2008
        • 495
        thanx for the input.
        i have remedied this by wiping the trail of the leak and wrapping it with a lil bit of electrical tape, i then put a thin plastic sheet to keep any further leaks in and not on my damn oem floormats =( it's kinda mickeymouse job but it'll do temporarily.
        my brake lights are now working though!
        but damn. $37 for that stop light switch from the stealership.
        -jeff
