Headlights: Will these go on an E30
  • Nicademus
    • 2912
    Curious if these Lucas PL700 headlights will fit on an E30: touch me please
    Is there any sort of rule of thumb on how to determine headlight fitment? or perhaps a list of ones that work? I've been looking around and noticed about 5 different options so far that work.
    and perhaps these ones too from the same seller (these both seem to be Jaguar headlights if that helps): Poke the link
    Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
    ~ John Adams ~
  • ethree
    • Aug 2007
    • 1216
    I think basically anything in the 5.75" diameter will work but most will require some bucket modification. I have no idea what a jaguar headlamp bucket looks like but the guys at http://www.rallylights.com have been super helpful in specific you'll want something like these http://www.rallylights.com/hella/5.75_lo.asp HTH.
    • Danny
      • 14216
      Someone compiled a list of lights that work.
      Lemme see if I can find it, oh here it is.
      Headlights that work on an E30:
      E30 headlights.
      • ethree
        • Aug 2007
        • 1216
        E30 headlights.
        :roll:
        Also add mercedes headlights, vw headlights and probably jaguar headlights. It all depends on your willingness or capability to "customize" your buckets or fab some sort of mounting bracket.
        • Nicademus
          • 2912
          E30 headlights.
          You're a tard.
          Those Hella's are really nice. I've seen them in person (not sure what model they're but I remember they cost a bundle and were quite hard to source).
          Thanks for the info ^^^. Yeah I have no problem splices wires and what not. My buddy has some random headlights on his E30 M3 that look really good, but we had to fool around with some stuff.
          ~ John Adams ~
          • Danny
            • 14216
            Originally posted by Nicademus
            You're a tard.
            Yes, but in all seriousness I would think the amount of work that would go into modifying a headlight to work in an E30 would outweigh just buying E30 lights.
            • Nicademus
              • 2912
              Not if they're better or unique. I love E30's because you can do some many different things to do them. I come from the IS300 which you can't do too much to, nor would I want to do any of the stuff available to it for the most part.
              ~ John Adams ~
              • ethree
                • Aug 2007
                • 1216
                The sets from rallylights.com wire in directly, the problem is that the "tabs" that align the lamps in the buckets are not in the right place so you need to notch the buckets to get the lights to line up properly, I used an angle grinder but a dremel or a bench grinder would work well. They look really nice and weren't too expensive, not much more than the links you're looking at.
                • Stephen
                  Шлем ишака
                  • 10774
                  The only thing with those is that lucas electronics are what give old jags their reputation for horrific reliability, whether or not that would affect something as simple as a headlight i'm not sure, but just something to keep in mind..
                  • Nicademus
                    • 2912
                    Thats good to know, thanks :)
                    ~ John Adams ~
                    • Stephen
                      Шлем ишака
                      • 10774
                      no prob ! :)
                      • Sam Cogley
                        • Jun 2008
                        • 521
                        No, you're a moron. Anything that's designed to fit a standard 5.75" sealed beam frame (like, say, any H4/H1 light sets) will fit the sealed beam frames for an E30. The alignment points on the back are exactly the same.
                        • Danny
                          • 14216
                          Well obviously yes I am a moron.
                          Excuse my ignorance.
                          • ethree
                            • Aug 2007
                            • 1216
                            No they're not. They all have different mounting tabs, all 5.75" lights do not line up perfectly in e30 buckets, nor in vw buckets.
                            • Nicademus
                              • 2912
                              Wow, good thing I didn't buy the ones I was looking at today. :o
                              ~ John Adams ~
