US spec crosshairs?
  • el_gringo
    • Mar 2008
    • 299
    US spec crosshairs?
    ok so i have that template of the smoked cross hairs layout your supposed to get, cut and install. sure, cutting is no problem, but the cross hairs dont fit all the way....
    1. they dont sit all the way back AND close enough to the lense, and i thought they should, right?
    2. towards the lense, they make a flat edge but the reflectors dont... it makes a small gap as well.
    3. around the part where you put a hole in and tighten down the crosshair, there is that lip. what is it for? allow light to travel behind the crosshairs?
    what would happen if i made a crosshair like this:
    obviously my idea is on the right, and will require some trimming as its not exact... im just going into a ballpark idea here.
  • txleadfoot
    • Apr 2006
    • 208
    what is this for?
    • Kingb
      • 928
      Do a search, there is a whole right up on what these are.
      Originally posted by Nicademus
      My car beats off to that car. :bow:
      • T Verdier
        • Aug 2007
        • 2636
        Originally posted by txleadfoot
        what is this for?
        Smoking yor head lights. the black cross hairs reflect of the chrome surface on the inside of the light causing it to look black and still maintain light output.
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          No, its fine for it to sit off the surface, cuts down on heat contact as well. It's worked for everyone else, perfect the way they are designed, don't hurt your brain trying to re-do it over again.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            And then I realized I replied to a thread from a banned member.
            • Atreus
              • 1846
              1991 325iC - Mauritsblau sumthin metallic blue. DEAD
              1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
              1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
              1991 325iC - Calypsorot Metallic
              1994 540i - Granitsilber
              Originally posted by scabzzzz
              I've had blunts cock in my mouth, but I'm not gay.
              • bpui
                • Nov 2008
                • 10
                hahaha
