HIDs for Euro smilies
  • boomer
    • 3019
    Just bought a 35w 6000k kit from DDM.Problem is
    it looks like I'll have to splice into car's wiring in order
    to power up the HIDs .Anyone encountered the same problem?
    Any solutions?
    http://www.arghon.com/
  • hendrixvodu
    • Jan 2007
    • 2514
    that plugs into an h4 harness
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
    • ///M42 sport
      • 3952
      noob search.
      • boomer
        • 3019
        Thanks
        Originally Posted by ///M42 sport
        noob search.
        In a condescending mood are we?
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          Originally posted by ///M42 sport
          noob search.
          no likely, this topic is covered all the time.
          you need to provide more pics of what youre working with. cause the majority of hid kits ive ever seen have a 9006 socket on the power wires going into the ballasts. in your case it looks like you need to chop off the terminals (which to me makes the kit look like its used, but thats just me i could be wrong) and wire the red to 12volts and the black to your ground. unless you have sealed beams this shouldnt be to hard to figure out with a voltmeter.
          i guess in this case he is right though, this is a noob subject as you should be able to figure it out on your own before asking. seriously, its 2 wires?!?!
          • boomer
            • 3019
            Have you ever connected a HID kit to euro lights?Because nowhere
            in my post did I ask for someone as clueless as me to give me advice
            on how to wire up this kit.
            I get the impression that you and mr m42 only posted in order to show
            the world what wise-asses you are.Nothing on the ballast connects to
            the headlamp power plug.That's why I asked if anyone else had encountered the same problem.
            You and the other character ass-u-med that I didn't do a search,when
            in reality,I make a point to search just so I can avoid douchebags like you.In any event I plan on resolving this problem without the help of
            any cyber jack-asses.
            • smonkbmw
              Professor
              • Jun 2006
              • 4549
              lol, orly?
              Any solutions?
              well, no one viewing this thread can tell what the fuck youre talking about as the only thing i can see in the pic is a hid bulb, ballast, a red and a black wire and youre fucking safety blanket. before you start accusing people of who the d bags are around here, post a legit question. because from what i see i answered your question given the information given and your sorry excuse for a picture.
              • boomer
                • 3019
                It's obvious all your reading material contains pictures.
                If you were
                to read the first line of my original thread,(v e r y s l o w l y)
                now go down to the sentence that starts with the word "Anyone".You
                would see
                there's no need for pictures.Nor would there be a need
                for you to reply to this thread.
                • ///M42 sport
                  • 3952
                  I posted pictures before your thread.
                  • T Verdier
                    • Aug 2007
                    • 2636
                    http://r3vlimited.com/board/showthre...=113251&page=5
                    :ohsnap:
                    • Van Westervelt
                      • 9365
                      We need more info.
                      #1, What year and model is your car?
                      #2, Does it have the factory wiring still intact, or is it removed/altered for the Euro lights?
                      #3, In order to help you, does you kit look just like the kit show below from the thread listed above? Pictures and more info are needed.
                      #4, Dont ask a question and then cop an attitude when people are offering advice or asking for more info, it will only hinder your request now, and any further.
                      • WhiteE30ic
                        • 99
                        Hey, I had the same issue, but I just finished installing and it works great.
                        First, cut off the spade connectors and pull the red and black out through the grommet.
                        Then drill a 1" hole in the back of the headlight cover and put the bulb in and feed the wires through the hole and fit the grommet.
                        Then cut your wiring harness and connect the brown to black and connect the red to the 12v source (depends on your model i think, use a test light or multimeter.
                        Plug the ballast into the connector from the lights and you are done.
                        Literally took me under an hour to do low and high beams.
                        • Van Westervelt
                          • 9365
                          Shouldnt take you more than 15 minutes, and all that work isnt needed on all setups.
                          Also, dont just connect based on color. Use a meter or the like to check your wires and connections.
                          • bimma360
                            • 1940
                            Hey thanks for those that posted some info in here. So i take it that the HID male connecters with the black and red wires are what plugs into the car's harness. And depending on the car's year that will determine whether its plug and play or if you need to do some cutting. Right?
                            Dave
                            E30 Dinan Turbo
                            • WhiteE30ic
                              • 99
                              Dave
                              The black and red are what connect to the wiring harness, I am pretty sure it won't be plug and play. If you had US headlamps in there you will need to cut the plugs (that go to the sealed beams) off and then use the multimeter to find the hot and ground (with the low beams on only) and you will be good.
