smoke crosshair question
  • bpui
    • Nov 2008
    • 10
    hi guys.. i cutted out the crosshair to smoke my e30 high beam. can i use a driller tool instead of using a dremel to drill the headlight ? i have no idea what tool do it beside dremel. i'm afraid that i might damage the headlight
  • ///M42 sport
    • 3952
    dremel cutting wheel. Just make sure you take careful measurements since you only get one chance to cut.
    • AndrewBird
      The Mad Scientist
      • 11898
      Depending on what kind of metal you used, you might also be able to just use tin snips. A jigsaw would also work well.
