Map light install
  • Kingb
    • 928
    Map light install
    Ok so I got the mirror with the map lights and am going to install it sometime. When I took it out of the other car, the wiring was ran inside of the body and not light the power sunroof cable. So instead of pulling it all the way through and feeding it back that way I should be able to tap into the sun roof power supply right?
    Originally posted by Nicademus
    My car beats off to that car. :bow:
  • dr.strangelove
    • Jan 2005
    • 847
    You can tap into the wiring off of the check panel, just match the colors up. there are two of the same color on one of the wires, and you just have to make sure one has the 12v. I ran the wire through the body, and it honestly wasn't "that" hard. takes a little time though...
    • Japandrew73
      • 2164
      if u have crank sunroof and no check panel then ur only option is running it fown right? and where exactly do u run it to?
      • Nicademus
        • 2912
        No check panel? What do you drive?
        Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
        ~ John Adams ~
        • dr.strangelove
          • Jan 2005
          • 847
          you run it down to the connector that is behind the speaker on the driver's kick panel.
          • Asbradley21
            • Jun 2008
            • 1938
            A 318? The check panel blanks don't have an live 12v source.
            You can run it from the lights over the doors.
            S54B32 swap in progress. Status: Getting There
            • gearheadE30
              • Jun 2007
              • 3734
              I ran my custom dome light power to the existing dome lights. It's pretty easy to do with the hanging headliner.
              Project M42 Turbo
              • Kingb
                • 928
                I do have a check panel. I was thinking that i might just run the cable with the power sunroof cable instead of running it through the body like it is now. Can't wait to install it and have to car running.
                • mikeedler
                  • 6707
                  just run it to the fuse/junction box. that way you can wire it up so that it goes off when you pull your keys out.-- never know in the summer if someone plays witht eh switches and leaves the lights on= dead battery.
                  • sheefo2k
                    • Nov 2008
                    • 97
                    is there a good diy anywhere on this?
                    Super E30 newb
