Hi-beams don't work after replacement?
    I bought some cheapo auto-pal lights off of ebay. for 45$ i got two h4 low-beams w/ city lights and two h1 hi-beams. The low's wired up fine and work great, but the hi's required me to cut the stock harness end off, and wire up the two hot leads to a single positive connector, and the ground, to a ground connector, to plug into the new hi-beam enclosures.
    I used a multitester to test that there was 12-13V DC going through the new positive connector, before i plugged them into the lights.
    Then, once i turned the lights on, the hi's wouldn't work, low's perform beautifully.
    So i got out my multitester again and tested to make sure current was flowing. Now it isn't? i tested the bulb itself for resistance and found it to be at 2-3ohms, which indicates to me that the filament inside is fine.
    So i figured i must've screwed something up somehow, and went about wiring up the second lighting assembly. Same problem. Had current before i tried the light w/ the new connectors, but once it got initial powerflow, no current runs anymore.
    Also, when i turn on my high's, my low's turn off. So it seems like there is no power flowing to anything related to the hi-beam system, since the h4's in the low's are dual filament, they should be staying lit once it kicks over to hi's.
    Wtf did i do? How do i fix it?
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
    Check your fuses and relays.
      upgraded wattage bulbs in the highs will blow the factory 7.5A fuse no sweat. Upgrade to a 15A
      Below the radar...
        Yup, that's what happens. But I'm running 10A fuses with 100w high beams and they're okay.
        '86 325 2.8i stroker - Arctic Blue
        '11 328i Sports Wagon - LeMans Blue
        Strictly Eta
          ah, gotcha, i shoulda figured that upgrading from sealed beams would do that. thanks guys.
          Whats the best place to get fuses at for cheap?
            ANY autoparts store. All fuses are cheap.
              thanks. picked up an assorted pack with a few of everything, along with a free tester tool for 15$ all in all @ schucks. You guys were right! those two were blown, all the others test good. I replaced them with 15A fuses and the lights work great! now i gotta aim these suckers cause they're WAY messed up:)
