As the title says I need help getting the part numbers for the correct connectors and wires to rig up my Bosch Euro Ellipsoid headlights.
Mine are used and didn't come with any connectors. I've searched around but I'm still a little confused. I found this write up by X-Mon and he's got two styles of connectors and wires to choose from. I'm planning on going through the dealership because I need to order some rubber bushings for the lights as well.
Can someone clear up what exactly I need?
I've included the wiring suggestions by x-mon here. These are for 'converting from sealed beam to euro ellipsoids using a single filament bulb.'
Keep in mind that I'm just planning on splicing them directly to my existing wires. The simpler the better.
Flat*Style*Connector*Housings***
61*13*1*378*401* High*Beam*Connector*(White)*
61*13*1*378*402* City*Light*Connector*(Grey)*
61*13*1 378*403* Low*Beam*Connector*(Yellow)
Flat*Style*Wiring*Pigtails
61*13*0*007*441* 0.5mm‐1.0mm*Wiring
61*13*0*007*442* 1.0mm‐2.5mm*Wiring
Right*Angled*Style*Connector*Housings
61*13*1*378*417* High*Beam*Connector*(White)
61*13*1*378*418* City*Light*Connector (Grey)
61*13*1*378*419* Low*Beam Connector (Yellow)
Right*Angled*Style*Wiring*Pigtails**
61*13*0*007*445* 0.5mm‐1.0mm*Wiring
61*13*0*007*446* 1.0mm‐2.5mm*Wiring
