De-pinning tail light connector 1382525
  • BonnieJean
    • Mar 2024
    • 7
    the connector for my tail light is crumbling into dust and I've purchased a replacement from eBay. I could splice the wires, but it would be cleaner to pull the pins and switch the wiring over to the "new" connector. I can't quite make out how these are held in place. Does anyone have experience they can share about pulling these pins?
  • ghrays
    • Jun 2017
    • 272
    When I bought new 61131382525 connectors from my local dealer's parts department, they let me borrow a special BMW de-pinning tool from service while I changed them over. I believe it was similar to this one:
    Replaces OEM part no. 83300495385 (OEM Price: $75 USD). Our tool is almost half the price of the OEM dealership tool. A must-have for e30/e36/e39 and other BMW engine swaps & wiring projects. Works on E30/E36/E39 Era BMW vehicle engine harnesses. De-pins female and male 4mm circular connectors. Can even de-pin the O2 sensor connector. C101, C191, X20, X69, X6031, X33, all confirmed compatible connectors
    • BonnieJean
      • Mar 2024
      • 7
      Thank you, I had seen that but wasn't sure if it would work on the tail light connectors. I'm stubbornly DIY anyhow and since I have a small machine shop, I decided to make a very primative tool.
      For anyone in the position to DIY it, I bought a 3/16 x 0.014" piece of brass tubing from Ace hardware for $2.79. I'm fortunately to have a big lathe so I chucked it up in a collet and turned 0.006" off the wall thickness. It's a perfect fit and pressing this over the tabs from the front, I could pull the wires from the back with a toothed needle nose plier. Obviously a little tube doesn't have the convenience of an eject pin, but for my little job it's enough.
