This Head Unit Installtion is making me chain smoke, some advice may be needed
  • TommyS
    • 1
    I recently bought a nice Sony Headunit and 4 Pioneer 5.25" Speakers. I decided to not purchase an amp and power the speakers through the head unit amp. I ran fresh beautifully concealed wires from the deck to all four points. For the rear, I ran them right down the center console, underneath the carpet and undearneath the seat. I attached them nicely to the back of the top panel and lead them into the speaker slots. Getting underneath that carpet and feeding the wire through was a real pain in the butt. I shoulda ran them down the left side of the car.
    Anyways, after removing all the old equipment and sealing off the old cable ends, I install speakers. The stock covers and grills won't fit with these new speakers so I Dremel around them and build and screw on some new grills I fashioned using parts from the Pioneer grills. It was a hassle but I like to have a clean look to my car.
    Now it's 5AM and I'm in my garage taking down cigarettes... Why? Because I tried to install my head unit (and because I'm an addict). Every wiring diagram I've read seems to not apply to my car. I have a 1989 325is (production date 11/88 ) with the factory premium system. Almost everything I've researched has lead me to the following...
    Code:
    Constant 12V+	Red/White
    Switched 12V+	Purple/White
    Ground	Brown
    Illumination	n/a
    Dimmer	n/a
    Antenna Trigger	White
    Antenna	Left Rear
    Front Speakers	5 1/4" Kick Panels
    Left Front (+)	White
    Left Front (-)	Black
    Right Front (+)	White
    Right Front (-)	Black
    Rear Speakers	5 1/4" Side Panels
    Left Rear (+)	White
    Left Rear (-)	Black
    Right Rear (+)	White
    Right Rear (-)	Black
    I don't have half of those wires in my E30. So... I've been looking at the Electrical Book for my E30 and I can't figure out where I'm supposed to get Constant, Switched, Antenna Switch and Illumination.
    I noticed there are 2 white wires. One is plugged into some sort of loop of cables and the other has an insulated connector at the end. I have figured that the one with the connector is the antenna most likely, but that's about as far as I've gotten...
    So, I have a few questions...
    Does anybody have any insight or any direction they can point me in on where to find those 4 necessary connections?
    The ground that was screwed on to the factory unit, can I use that for my aftermarket HU? I don't know much about electronics and common ground and what not.
    The Amp in the trunk? Can I just remove it and seal off what ever connectors were there?
    I think I'm gonna get some sleep and try again tomorrow. I'll post up what ever I learned after this incase somebody else is as stupid as I am and needs some help. I need to finish this soon as it's timing belt time this weekend and I'd like a day away from my little E30. Any help would be very much appreciated!
    - Tommy
  • AndrewBird
    The Mad Scientist
    • 11892
    Check this out, page 98:
    Taken form the above:
    Ground - Brown/Black
    Constant - Red/Green
    Switched - Violet/Grey
    Antenna Trigger - White
    The ground screwed to the case is common ground for the speakers. Don't use this to ground the new HU. Use the Br/Bl wire.
    Yes, you can just remove the factory amp. Or just leave it. It won't affect anything.
