Spalusa? switches?
  • thereisnoyun
    • Feb 2007
    • 2301
    Spalusa? switches?
    so if you go on spalusa.com and look up switch kits nad switches they have for sale. You will see a e36 switch, with a built in base that looks like it will wired up straight to the e30. anyone tried this? if this old news?
    the page
    the switch
    the pdf
  • 4drPwr
    • 370
    Bump for any thoughts on this...if it seems like a viable option I'd entertain being the guinea pig for it.
    86Zinno
    • StereoInstaller1
      GAS
      • 22679
      What kind of feedback would you like?
      I have done a few sets of SPAL switches, including those.
      I prefer E36 green base switches over anything.
      Closing SOON!
      Thanks for 10 years of fun!
      • 4drPwr
        • 370
        How much effort is required to retrofit these into our cars? Obviously I'd prefer to use genuine BMW E36 switches but in my experience they typically run for alot more than $13 per switch, used nonetheless.
        86Zinno
        • thereisnoyun
          • Feb 2007
          • 2301
          1.) do they light up amber?
          2.) how easy is it to wire in?
          • StereoInstaller1
            GAS
            • 22679
            Originally posted by 4drPwr
            How much effort is required to retrofit these into our cars? .
            Quite a bit, but only mounting. These need to snap into a plate, and as they are flimsy as hell, any stress in the mounting makes them not work, or bind, or both.
            SPAL is decent stuff, but nowhere near OE quality.
            I have seen this same switch in green, but most are amber. They do use a tiny lightbulb with a color sock, so that is changeable, or solder in an LED.
            Of course, LEDs are better as they help prevent the heat issues
            Pretty easy, all in all. Figure the E30 has 2 window motor wires, a hot and a ground, and so does that switch. If you wanted variable illumination (which the E30 switch is not capable of) you cold run a wire over to the cigarette lighter socket.
            Yeah, but don't forget that switch does not come with any kind of plug.
            You can make your own pretty easy though, just label the damn wires!
            GL, guys.
            Luke
            Closing SOON!
            • StereoInstaller1
              GAS
              • 22679
              This frame (33030079) is cheap flimsy plastic, but on the nice flat E30 console, it might work well.
              Closing SOON!
