i need your opinions guys!
  • Mrpopaul
    • Apr 2009
    • 53
    i want a good sound system but i dont want anything too big and heavy for the car.And also i want a little but not too much bass so i was thinking on installing two of these in my rear deck.
    Do you guys think it's doable?What amp should i use for two of these?
    All opinions and flames are welcome!thanks guys
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Luke, oh luke, where art thou luke?
    • StereoInstaller1
      GAS
      • 22679
      What I think is that a Fs of 38Hz and a Qtc of .4, with a 13mm XMAX should sound OK, and play fairly low.
      The 83db sensitivity means this thing is never ever gonna play loud, but WTF, how much are you looking for?
      Power handling should be OK with damn near any amp...if you wanted to be able to get every damn bit of loud out of them, a basic 500WRMS 2 ohm mono amp would rock their world.
      50WRMS power handling is kind of suprising, considering the 1.5" voice coil...should be more like 200RMS.
      Anyway, WTF, give them a try!
      Excellent performance installed in auto rear deck
      Thursday, February 5, 2009
      Andrew from Simi Valley, Ca.
      My Toyota has a 6 1/2" factory cut-out in the rear deck. I didn't want to lose any trunk space with a bass box. These drivers fit in the factory cut-outs. With 13mm x-max, they perform more like a much larger driver. To greatly improve bass response and dampen deck vibrations, I bolted 5 lbs. of lead to the center bottom rear deck. I'm driving these with a $30.00 MTX 50 watt RMS / channel amp. I set the crossover to 120Hz. They have great midbass impact and also go down really low. I'm using Dayton's PA-130-8 5" PA drivers and ND20FA-6 tweeters (shelved -12dB) in the doors. These Dayton drivers way out perform Polk door speakers that I replaced and cost 1/3rd as much.
      Closing SOON!
      Thanks for 10 years of fun!
      • woodisgood
        • 1087
        Curious about this too as I was looking at these same speakers for a while, I was toying with the idea of a PVC pipe box for them..decided I didn't know what the hell I was talking about and that I should just shut up...plus the pipe would have to be too long.
        • Mrpopaul
          • Apr 2009
          • 53
          Hey Luke can you recommend a good 2 channel amp please.
          • StereoInstaller1
            GAS
            • 22679
            Why?
            Closing SOON!
            • Mrpopaul
              • Apr 2009
              • 53
              Hey Luke what do you think about these? Just found them about a minute ago!
              Thanks!
              • Mless5
                • Jul 2006
                • 817
                Thanks!
                3mm xmax will not get you far and the basket looks rather flimpsy.
                '96 328is
                '97 m3
                '04 zhp
                • Mrpopaul
                  • Apr 2009
                  • 53
                  I thought so too but I just wanna hear from you guys that have better knowledge when it comes to sound systems. Thanks Mless5
