my e30 = electircal nightmare!
  • xLegendOZWest
    • Jan 2009
    • 406
    so i have no. dash lights, no tach, no speedo, no econ, no water temp.
    no passenger side tail light. no plate light. and im sure somthing eles.
    all fuses are good. any ideas o n what to test for the cluster or am i better off looking for a new.
    on a side note the car is a 5 speed swap with a M50 B25 (NV).
    thanks guys.
    Live Fast. Drive Faster.
    "Nitrous is like a hot girl with an STD... :)
    You wanna hit it, but your afraid of the consequences :(
  • MattM
    • Apr 2009
    • 931
    Most likely its going to be a main source thats out.
    have you checked the wiring adapter made for the engine? did you do the swap, or did you buy it swapped? the temp needs a special connector to work, and if its a PFL car you need to hook up the C104 connector in the glovebox to have the tach work/econ guage(it will not be accurate though)
    Also the speedo sensor could be disconnected or shot, it is in the Diff.
    Last thing, maybe there is a short in the fuse box, open it up and have a look at the wires, to cause that much it would be a pretty extensive mess(fire maybe?)
    Its possible that your almost everything in your car is toast(dash, tail light, backlights etc) but its more likely that they just arent getting power or signal
    Full Build Thread Here
    • TexasTerp
      • Jan 2009
      • 3541
      Try testing the SI board battery and the board itself, that should cover the majority of the cluster problems.
      stephenbrody.com
      • xLegendOZWest
        • Jan 2009
        • 406
        how would i do this?
        • StereoInstaller1
          GAS
          • 22679
          How did you test the fuses?
          Closing SOON!
          Thanks for 10 years of fun!
          • xLegendOZWest
            • Jan 2009
            • 406
            i looked at them to see if they were blown. and they wernt.
            • AndrewBird
              The Mad Scientist
              • 11892
              Fuses can look fine and still be bad. Try replacing the one for the cluster and see what happens.
              Sounds like maybe a connector is loose or unplugged.
              • Goya20
                • 325
                hey man i had the same problem. u said it was swaped to a 5spd right check the reverse wire under the boot it may be pinched against the chassis tape it up and tape the chassis to provide and cushion so insulation wont be cut and therefore creating a short.
                • xLegendOZWest
                  • Jan 2009
                  • 406
                  interesting thought ill look into that.
