I have a four door ('91), and am putting an EQ under the driver's seat (Audio Control EQL). I have mounted my coustic XM6 inside the trunk on the driver's side side panel, behind the carpet. From there the signal is just going to a sub amp for now, but eventually ima add some more amps to run the front components and some front midbasses. I want to run all the wire now, however.
Anyway, what is the easiest way to run the RCAs to the under-driver's-seat area? The most-direct route down the tunnel, then under the carpet to the slit for the heating ducts under the seat, looks pretty tough to do due to the stiffness of the carpet.
The other option is running the RCAs over to the kick panel area, then down the side to the under seat area. I also have to go from there to the trunk.
How do you get the sill trim pieces (that hold the carpet down) off? Do they come straight up, or slide back or forwards first?
TIA!
TIA!
