Speedometer...again.
  • r0meyrome
    • Jul 2009
    • 218
    Hey so Ive searched around and havent found a good answer to help me fix my problem. Here it goes in cliff notes form.
    Original Cluster All Gauges works fine. Tach,Speedo,Fuel,Temp.
    Swapped in Euro Cluster. Tach,Fuel,Temp all works.
    Speedo works sometimes and sometimes doesnt.
    Checked the solder and its ok still.
    I pushed in the little wedges that the speedo connects with the clusters and it helped! It made the speedo work but after a couple of blocks or hitting a bump it 0's out.
    Whats next to try? Im canceling out the diff speed sensor just because it worked perfectly before this swap or should I check anyways?
  • r0meyrome
    • Jul 2009
    • 218
    Just went for a drive around the block with the car sitting for about 3 hours and the speedo worked again...Now im thinking it might be the sensor...
