lookie what i found.......
  • nadodude111
    • Jul 2009
    • 432
    for only 50 bucks! i cant believe i found it! it took forever but finally got my hands on one. they're so hard to find. (its the alpine one lol)
    the black wire is the ground, the yellow is for power. where do you guys suggest i connect the yellow in the trunk? if worst comes to worst ill just run a long wire from the ignition (green wire) to this. thanks
    1992 325i Convertible
  • lennon
    • Jun 2008
    • 1416
    too bad you have a vert
    • StereoInstaller1
      GAS
      • 22679
      You can use the power wire from the trunk light to power that changer, or the red wire at the power antenna.
      Closing SOON!
      Thanks for 10 years of fun!
      • nadodude111
        • Jul 2009
        • 432
        go idea about the trunk light. i do not have a red wire at the antenna.
        • StereoInstaller1
          GAS
          • 22679
          You have to have a constant wire at the antenna.
          Whatever the not-white one is
          Closing SOON!
          • nadodude111
            • Jul 2009
            • 432
            the power wire is the big black cable looking thing that is too thick to splice into.
            • Vince30
              • 2318
              No thats your antenna wire, there is a little power wire that makes your power antenna go up and down.
              • slow e30
                • Jul 2009
                • 398
                it should have wires inside of it. pull that cover off the inside of the trunk and look for the red wire. i wouldnt say or argue there isnt a red wire to the antenna when the guy who suggested it wires in these cars often. its a quick way for a one way ticket to banville.
                • nadodude111
                  • Jul 2009
                  • 432
                  i dont have my car right now as it is in the shop for electrical problems and i cant remember what wires are in there sorry. if i had my car i would have checked yesterday.
                  • StereoInstaller1
                    GAS
                    • 22679
                    No no, none of that. Bannage is NOT me, arguing is no fun, but since I am 99% right 99% of the time, its OK.
                    It is NOT the thick wire though, I promise. That would be the antenna wire, the actual signal cable. Don't fuck with it unless you already know what you are doing.
                    OK, so I just looked at the ETM. The antenna DOES have a red wire, from fuse 28, 30A. The wire is red/yellow until the antenna plug, then it is red.
                    There is also the white wire, which is the trigger that sends the antenna up when it gets +12V from the radio.
                    Hook your changer to that red wire, all will be fine.
                    Luke
                    Closing SOON!
                    • nadodude111
                      • Jul 2009
                      • 432
                      thank you! i googled the antenna and i saw the red/white wires. thank you so much!
