sitting for 2 years and no start !HELP!
  • OlD TiME BiMmer
    • Sep 2009
    • 3
    Hey guys, havnt been here for awhile now, but, IM BACK!...
    I got a stock 1990 325i
    anyways the kitten has been in the garage for the last two years. *Sudden things came up*
    So I filled it halfway with gas, replaced the fuel filter, fuel pump, main relay and the fuel pump relay. No fuel comes out of the fuel pump.
    the battery has 12.64 volts.
    I get 1.64 volts to the fuel pump, main relay and the fuel pump.
    I tried to do some tests to the motronic 1.1 system and nothing.
    The motronic 1.1 system doesnt get any power.
    The headlights come on, the heater fan works, and all the light turn on when the key is in the "on" position.
    There is no sign of rodents and the car cranks and cranks.
    The starter is good, spark plugs, wires, dist cap, rotor are all good.
    O I also checked the pulse sensor and it was good.
    I think its the fact that the motronic system is not getting enough power
    any thoughts!?
  • svn2002s
    • Sep 2004
    • 472
    Check your fusible link. It feeds the motronic which feeds the relays.
    • OlD TiME BiMmer
      • Sep 2009
      • 3
      Is the fuseable like 6 in from the positive or gound wire from the battery?
      Also, IF the fusable link is bad, would The lights, windows and everything else turn on?
      • svn2002s
        • Sep 2004
        • 472
        Is the thin wire that goes to the positive. Remove/cut the rubber sleeve that protects the board type material to see it. Best way to replace it is to go the the junkyard and get that piece of wire (10 in.) with the terminal and replace yours.
        If it's bad, lights, windows, sunroof etc will still work.
        • ejnight
          • Apr 2007
          • 3488
          engine ground?
          http://raceskids.com/
          • OlD TiME BiMmer
            • Sep 2009
            • 3
            SVN2002s, How much do I owe ya!??!? your right!
            I love this forum! I don't remember why I left..
            THANK YOU ALL!
