Where to tap for voltmeter?
  • evilnickwong
    • Aug 2007
    • 302
    I'm gonna install a voltmeter soon. For it's light, I'll just tap into any of the light wires around the center console/dash area so that it can dim along with the other lights using the knob.
    But where should I tap for the signal?
    Can I just use any random 12v ignition source, or must I get it direct from the ignition column? If not, then where's the most convenient ignition wire to tap into?
    Also, if I tap to a acc. wire (e.g. radio or glove light), I read that I won't get a reading during actual ignition/starting of car and thus cannot see my startup voltage. Is this true?
  • Aptyp
    • 6584
    Right on the firewall where the power distribution is. Right over where engine harness goes into firewall.
    • evilnickwong
      • Aug 2007
      • 302
      That would be on left side of firewall right? (driver's side for LHD car).
      Which wire specifically, is there a single color for it?
      • StereoInstaller1
        GAS
        • 22679
        If you want to see the actual voltage drop when starting, you would want to catch actual voltage off of the ignition wire.
        IIRC, it is green and in the ignition harness.
        Needs to be live in run and start.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • evilnickwong
          • Aug 2007
          • 302
          OK got it thanks.
          Otherwise, if I connect to an acc. wire, it won't give a reading when starting, but thereafter when running I can still monitor it, right?
          • StereoInstaller1
            GAS
            • 22679
            Originally posted by evilnickwong
            OK got it thanks.
            Yeah, you go it.
            Closing SOON!
            • b*saint
              • 3794
              Just if you wire it to the ignition wire make sure its parallel not series. Your volt meter will NOT handle the amps and WILL go up in flames as happened when my friend wired up his own horn in series with the ignition coil.
              Ma che cazzo state dicendo? :|
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                Meh
                mine is on my accessory wire. Works fine.
                Yours truly,
                Rich
                you kids get off my lawn.....
                • AndrewBird
                  The Mad Scientist
                  • 11897
                  It took me a second to figure out what you are talking about. Your friend basically put the gauge inline with the ignition? Yeah, that's a no-no. All you need to do is tap into the ignition wire, run it to the gauge, then ground the other side of the gauge.
                  • evilnickwong
                    • Aug 2007
                    • 302
                    OK so I decided not to cut into my ignition harness, but took power from the wire that powers the glove box light instead. (the electrical manual pdf says that's active in acc, ignition + run)
                    I get these readings:
                    Ignition on, engine off - 12-12.5V
                    During crank - 10.5-11V
                    Engine running + audio, etc - 13V
                    Engine running + audio, etc + headlights = 12.5-13V
                    Are these readings OK? Or is there an inaccuracy taking readings from the glove box light wire? (I tapped into the wire before it reaches the light bulb socket, and the voltmeter is grounded to the cigarette lighter ground).
                    • Schnitzer318is
                      • Jan 2008
                      • 2057
                      Looks fairly accurate to me... My megasquirt readings are about a half a volt higher than yours for all conditions. I'm running an optima red top though... might help the charging system a bit.
                      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                      91 318is Turbo Sold
                      87 325 Daily driver Sold
                      06 4.8is X5
                      06 Mtec X3
                      05 4.4i X5 Sold
                      92 325ic Sold & Re-purchased
                      90 325i Sold
                      97 328is Sold
                      01 323ci Sold
                      92 325i Sold
                      83 528e Totaled
                      98 328i Sold
                      93 325i Sold
                      • evilnickwong
                        • Aug 2007
                        • 302
                        Thanks to all for helping a wiring noob out. :D Learning more each time I play around with my multimeter haha. Here's my finished install:
