Gague cluster goes crazy.
  • RLLOVER
    • Aug 2009
    • 18
    Hello and I am a newbie.
    Did the search and got info on them not working at all, but my water temp and oil pressure gauges go full high key on ignition on, and they never move from there.
    Previous owner said he replaced the battery in the cluster. Battery?!?!?! All right... sure.
    Plus the thing runs dead rich all the time.
    So I want to run this thing and see what the heck else it needs, but I'd rather be able to see what the engine is doing while I am doing it.
    Thanks,
    Randy
    It could be worse... you could be on fire... or like Chevys.
  • TrentW
    • 2815
    What is this oil pressure gauge you speak of?
    • RainierHooker
      • Jul 2009
      • 2026
      ^ This...
      But if we aare talking about the standard cluster, Yes, there is a battery in there (on early models).
      If it isn't the battery messing with your gauges, it is probably either a bad connection, a ground, or a bad SI board. The best thing to do is to pull the cluster and have a look-see around in there to make sure nothing is burnt or melted. If it isn't, carefully put it back together taking care with the connections. If it is screwed then you need a new SI board or a whole new cluster.
      It may be worth it to find a known-good cluster and just swap it in there. If this doesn't fix the problems it is time to dig deeper...
      1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
      • RLLOVER
        • Aug 2009
        • 18
        Thanks for the info.
        Holey crap! There is no oil pressure gauge on my dash!!!!
        Thanks for the info Rainierhooker.
