OBC Went Dim
  • WADE30
    • 249
    OBC Went Dim
    I still don't know too much about E30's. Is there bulbs behind the OBC that can go out or is it some type of switch or something that goes out? I can't read the time/temp/mpg/etc. anymore.
    And how do you take it out? Any secret method? I assume take out radio maybe? Glove box left side?
    Thanks guys!
    Wade
  • rhett325i
    • Jan 2005
    • 575
    you have to remove the panel that holds the OBC, HVAC, stereo, etc. Then the backlight piece slides out of the side of the OBC, and you slide in a new one.
    • ben312
      • Jan 2009
      • 1139
      they can break. you can buy a new one for a decent price. people on here make and sell them.
      Originally posted by Beej '86 325es
      every time an M-tech 1 spoiler is destroyed, a baby seal dies.
      Originally posted by Jparkr
      The last thing we need are more of the retards on here thinking they are engineers too.
      87 325:83 jetta coupe:99 volvo c70:99 volvo s70
      • bostonbmw
        • Nov 2004
        • 429
        Check these two links they have all the info you need.
        I've 'read' many posts, but without pics, it's hard to get a good visual. Well I have now repaired both my lights in each on me e30's. Here is my official write up and most importantly pictures! This version is the short cut (read: time saving) version versus complete removal of the front panel/fas
        http://www.pelicanparts.com/bmw/tech...eplacement.htm
        • WADE30
          • 249
          Hey thanks guys! Much appreciated.
          • cochran
            • Sep 2005
            • 78
            Be careful. The Pelican write up skips a screw that you have to take out, on the left hand side of the OBC. I nearly tore mine up before slowing down and thinking about it. Otherwise, fairly easy to fix and not expensive.
            Cochran
            '88 325iC - daily driver, work in progress
            • bimmer95
              • Oct 2009
              • 30
              If your SI board is on the fritz the OBC can stop lighting up too.
