I know that its a common issue for the odometer gears to go out in our cars but what about the speedometer? My speedometer is no longer working correctly, it only works like 50% of the time. Ill be cruising along and notice the needle fall to 0mph and because the speedo isnt reading any speed its also not spinning the odometer.
When this first happened I figured that it was the odo gears but I havent read anything about the speedo going out too. So is there a speedo gear that I need to replace?
Thanks
Thanks
