Coolant check light
  • SEdgell
    • Jan 2008
    • 348
    Coolant check light
    I have an 86 ES, every now and then when I start the car up it has the coolant light lit up. I'll check the level and it's fine, and it doesn't over heat. Usually when the coolant light is on if I turn the ignition off and then start it again the light will be out. Anyone had any trouble with this? Where is the sensor that controls this?
  • gabe74gt
    • Sep 2009
    • 5
    i had the same problem a year ago! but still cant pin out the problem. my technician says it will be ok by itself
    • TexasE30
      • Jan 2009
      • 298
      I have same problem. PO told me to replace coolant level sensor which is on top of expansion tank. It comes with breather. Dont take me on this one. Just a word from the po of my car.
