CAR:1989 325i with stock non premium 4 speaker system
So my car audio hasn't worked for quiet some time so i pulled the speakers and discovered this:
Anyways I am trying to find some SQ speakers to replace these.I am not adding a sub-woofer. So far I have found these:
Precision Power PPI 355CS
They are $75 on ebay from sonicelectronix.com
http://www.sonicelectronix.com/item_...PPI+355CS.html
Eclipse SP5010
They are $79 on sonicelectronix.com
http://www.sonicelectronix.com/item_...se+SP5010.html
Looking at their frequency response it looks like the Power Precisions go a little lower. Since I'm not getting a sub-woofer it would be best to get the lowest possible frequency response.Right?
Has anyone used these speakers before?
Is it possible to put slightly larger speakers in the stock location.
- 5-1/4" 2-way Component System
- Power Handling:
- Peak: 200 watts per set / 100 watts each side
- RMS: 100 watts per set / 50 watts each side
- Kevlar, mica, fiberglass interlaced cone woofer
- Silk dome tweeter
- Phase plug for controlled interaction between mid and high frequencies
- Woven tinsel leads
- 4 ohms impedance
- Copper clad aluminum voice coil
- Custom Crossover
- 12 dB High pass configuration
- 6 dB Low pass
- +3 dB Tweeter level adjustments
- 180ยบ Tweeter phase adjustments
- Multi stage tweeter protection
- Bi-ampable mid/mid-bass Zobel circuit
- Top-mount depth: 2-1/2"
Eclipse SP5010
- 5-1/4" Point Source Series Car Speakers
- Power Handling:
- Peak: 300 watts per pair / 150 watts each
- RMS: 100 watts per pair / 50 watts each
- Carbon fiber with cotton backing cone woofer
- Rubber surround
- 1" Silk soft dome tweeter
- Neodymium tweeter magnet
- 4 ohms impedance
- Aluminum voice coil former
- Ferrite magnet structure
- Top-mount depth: 2-1/4"
