E30 Amp ground cable?
  • slap2nd
    • Nov 2009
    • 22
    Where is the best place on the E30 to wire the ground cable to?
    I seem to be loosing power from my sound system and for some reason I think its not grounded correctly.
    Help would be greatly appreciated.
    Thanks.
  • netcsk
    • Apr 2004
    • 1609
    The same spot that the battery grounds is the best spot.
    • AndrewBird
      The Mad Scientist
      • 11898
      Either that or sand the paint off the car near the amp and ground it there. Depends on where you have it mounted though. You might also have ground loop problems like this, but I've seen many do it this way.
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        if your amp and battery are in the trunk, run a groung wire to the neg term on the battery
        -Andy
        • accident
          • 7303
          i grounded my amp to the powered antenna ground. no issues with it.
          Moral of this story?
          • slap2nd
            • Nov 2009
            • 22
            That is a good idea accually, since I dont even use the antenna! to many ads on the radio lol I prefer to listen to CD's or the engine :) haha
            I will try that and see how it goes. if not ill try to attempt to ground it to the negative on the battery, the only problem is I will need a long ass ground cable as the battery is in the front of the car and the amp is in the boot (trunk for u americans) lol
            Thanks guys!!
            • accident
              • 7303
              while your battery is under the bonnet, the battery ground point in the boot may still be there
              • StereoInstaller1
                GAS
                • 22679
                If you have the front mount battery, you will not have the noise issues us rear battery guys have.
                Scrape the paint clean on a spot on the floor, shoot a short screw through a ring terminal. No special anything needed here, except to make sure that you get all the paint off, as paint does not conduct electricity.
                Luke
                Closing SOON!
                Thanks for 10 years of fun!
                • bigdrick323
                  • Feb 2012
                  • 616
                  I need to do this as well at some point, any pics of a good location?
                  sigpicMy Project!
                  Official North Texas Bimmers Club E30 Representative
                  www.BimmerAlliance.net
                  "If you have questions about events or need help in the DFW area don't be afraid to contact me."
                  • bmwguy325is
                    • May 2011
                    • 1263
                    I only ever got a slight noise when the battery was low.
                    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                    • bigdrick323
                      • Feb 2012
                      • 616
                      Originally posted by bigdrick323
                      I need to do this as well at some point, any pics of a good location or.l bolt to use?
                      Bump
                      Sent from my LG-MS870 using Tapatalk 2
                      sigpicMy Project!
                      • bangn
                        • Sep 2011
                        • 760
                        use one of the shock mount nuts in the rear.
                        Boris - 89 E30 325i
                        84- E30 323i
                        • bigdrick323
                          • Feb 2012
                          • 616
                          I have a convertible
                          sigpicMy Project!
                          • StereoInstaller1
                            GAS
                            • 22679
                            Do NOT do this!
                            I fire guys for that bullshit, make your own ground point or use a proper factory ground point.
                            Closing SOON!
                            • treff-7
                              • Sep 2009
                              • 345
                              I used the one that's under the rear seat. I think the electric window motor grounds there...
