Passenger Front Turn Signal Stopped Working
  • GCARent
    • Nov 2009
    • 80
    Hello everyone,
    I have a 1986 325e with turn signals on front diving board.
    My front passenger turn signal stopped functioning after took out my DB and tucked it. I changed the light bulb and checked to see if the connector is nice, tight, and snug and it still is not working. All the other turn signals work except for that one. I checked to see if there was voltage coming out from the plug connector and this is what I found:
    The top one has no voltage output while the bottom 2 do have an output.
    Can it be a short on that wire only or is it supposed to have no voltage on that wire?
    All help will be appreciated.
  • kronus
    • Apr 2008
    • 13032
    If all three had +12v the lamp would not function. You have a fucked plug housing.
    cars beep boop
    • GCARent
      • Nov 2009
      • 80
      I just noticed today that my passenger rear diving board red light is not functioning as well. I didn't have time to check if its burnt but can that be the reason for my front DB Passenger Turn Signal to stop functioning. I know that for some cars, if one thing is not working, then something else stops functioning as well.
      • GCARent
        • Nov 2009
        • 80
        Problem fixed by moving the bulb around...
