Ok. Well do they make a full sweep? And not planning on doing this but will local auto parts store brand gauges work? But I like the vdo Its original.
					gauges
 Pretty sure they will but I think you'll need matching senders. At least for the pressure amount. I thought about cheap gauges, but for the cost difference, its not worth it to me. The difference is only a couple bucks really. This one would be perfect!
 http://www.jegs.com/webapp/wcs/store...-1&showValue=1RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
 Welcome e30 (brilliantrot '90 325is) 12/23/06
 DaveCN = Old Man
 My signature picture was taken by ME! Not by anyone else!
 Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
 Nevermind, that one is mechanical. You would have to have an oil line TO the gauge. Its not electronic so you couldnt use a sender and just run wires to the cabin.RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
 DaveCN = Old Man
 [quote=PeaveyBassist;1789947]Remove oil pressure switch. (pass side of block above drain plug, below oil filter) It will have a connector with one wire on it. Install this...
 Install this pressure sender. Cut the connector off the stock pressure switch. Put ring terminal on the end of the stock wire and install on warning contact of sender. You might need to add a little bit of wire to reach as well. Obviously you will need to get the 80psi VDO gauges for this to work properly.
 I dont quite understand what you mean by the warning contact? and this sender is good for the light and the guage? Comment
 holy old thread! i know...
 What sender do you recommend for a water temp vdo gauge?
 310-105 2 1/16 250F Engine Temp. - Elec. Vision Black
 What is the best way to install it?
 So far my shopping list looks like this,
 310-106 2 1/16 300F Engine Temp. - Elec. Vision Black
 323-092 Temperature Sender: 300F/150C - M12x1.5
 350-104 2 1/16 80 PSI Engine Press. - Elec. Vision Black
 360-006 Pressure Sender: 0-80 PSI/5 Bar - M10x1K - 7.0 PSI
 332-103 2 1/16 16 Volts Voltmeter - 12 volts Vision Black
 Thanks!Comment
