Amp question....sorry audio noob
  • bkelsey86
    • 1173
    I hae a 4 channel amp that I want to hook up to my pioneer head unit to run my infinity speakers inside the car. But there are only 2 rca jacks on the back of teh stereo labled L and R. The amp is 4 channel so it has L and R for bith rear and front speakers but how do I hook the amp up to run all 4 speakers???
  • kencopperwheat
    King of Kegstands
    • 14396
    Y- adapters.
    Any place that sells RCA cables will have some. You just wont be able to fade front to rear.
    Originally posted by Gruelius
    • bkelsey86
      • 1173
      Sorry but could you explain a little better sorry but I dont QUITE understand.
      • kencopperwheat
        King of Kegstands
        • 14396
        It's a cable that has ONE rca female input and TWO male rca outputs. It just splits the the cable into two. You'll need two of them obviously.
        It also sounds like you shouldn't be installing your own amp.
        • bkelsey86
          • 1173
          but that doesnt make sense since rigth now there are 4 male RCA's comign from teh amp and only 2 females on the back of the headunit
          • bkelsey86
            • 1173
            I'd take it to soemone if I didnt think that I could do it but its also kinda hard to take a car somewhere when you have the head off and are rebuilding it.
            • kencopperwheat
              King of Kegstands
              • 14396
              Run the RCAs from the deck back to the amp, not from the amp up to the deck. You can only use one pair of RCA cables. Put Y-adapters on the end of each of the rca cables. You split the left one into two signals and the right one into two signals.
              • bkelsey86
                • 1173
                yeah my bad i misread your thing wrong thanks for the help.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  No prob. Radio Shack should have some cheap ones.
                  • 808BMW
                    • 2910
                    If they don't and the only ones they have are like $25, you could try home depot instead of getting ripped off like me.
                    • bkelsey86
                      • 1173
                      well I finished the install and ran all new speaker wire and mounted my amp under the passenger seat and it sounds great, big improvment...I'm glad my car came with Infinity refrences from the PO. Thanks for all the help
