So I've been working on improving the audio in my 1990 325is. Its up on blocks right now while I replace the transmission and refinish the BMW Style 10's, so I've got some time. Keep in mind I know absolutely jack all about car audio.
The main body is a PVC pipe coupler cut in half, the ring was included in the speaker kit, it just needed to be slightly ground down. I beveled the outside edge to clean up the overall look. It will be painted and/ or wrapped in vinyl before its finished. I'm currently working on the mounting system.
I have a couple of quick question for the speaker and car audio experts on the forum:
1 - Do mids need to be in ported or sealed enclosures? Does it matter?
2 - Should I line the interior of the pods with sound deadening material? Insulation? Nothing?
How I mount the pods will change depending on whether I have to seal them or not. I plan on mounting them on the door cards (with a backing plate to hold it securely of course) near the hand crank hole.
The other hardware:
The mids and tweeters:http://www.madisound.com/catalog/pro...oducts_id=8472
The sub box has been painted and finished up. In the pictures its just tacked together, its since been completely buttoned up and had the ports added. The trunk of the 325is has had the trunk tar removed and replaced with sound deadening material with the sub box bolted down in several places.
The BMW in question:
