So I'm in the process of removing an aftermarket stereo (Blaupunkt Reno CM147) from the car, and I've ran into an issue. I'm to two wires left to disconnect from the harness, and there is a wire that isn't (quite) matching up with what existing electrical connection guides I can find.
From the head unit harness to the car harness, the two wires left are:
Red goes to green
Orange (extra yellow? the colors on the wires are pretty worn) goes to red/green
According to the wiring diagram on the top of the head unit:
Red goes to ignition
Black goes to ground
Yellow goes to battery
There's no orange wire listed in the diagram. I've already marked the battery and ground connectors (those were nicely labeled for me on the head unit harness as "batt" and "ground"), so that just leaves the ignition.
Before I cut the red wire and mark it as ignition, that orange wire in the harness irks me. I have no clue what that wire is for and where it came from. And I really don't want to pull apart the entire dash to trace that wire to figure out where it's going. So far Google has let me down into finding out what purpose the orange wire serves. Every wiring diagram I've found related to this stereo matches what is on top of the head unit.
Figure it's safe just to tape off the orange and leave in there disconnected? The new head unit doesn't have a use for that "extra" wire.
Anybody has any experience working with these Blaupunkt stereos and know what that orange wire might be for?
Red goes to green
[IMG]http://www.r3vlimited.com/board/
