1989 m20 engine harness
  • norwood e30
    • Mar 2007
    • 442
    Hello I'm installing a engine harness on my car. Now I do not want to burn out anything so I will like to install this the rite way. So far I have the 24 pin conector,starter,o2,coil and a few others are conected but the part I'm having a problem with is how to know which order the harness is to the oil sensor and crank sensor dnt want to mix those two up. Plus which order on passenger side firewall were ecu wiring goes the guy who previously own my car mix those wires burned the other harness out neAr relays May someone help me or link me a diagram thank Sean
