running wires...
  • kobe
    • 82
    running wires...
    hey guys, so i got a 89 325is. i just bought a bazooka tube and wanted to run wires from the factory deck to the trunk. my problem is how do i remove the door trim without breaking the tabs? also what the best place to run the wires..down the side or straight through the middel...any help or suggestion would be great. cheers!
  • digital_cowboy
    • May 2008
    • 335
    You will have to unscrew the door pull first. Then gently pull the door panel away from the door. Then slide it up and off. I know nothing about where to run wires, but I have always run them along the side of the car.
    -Will
    1987 325is, 1989 325i, 1997 318i
    Parts for Sale
    • Adrian_Visser
      • Jun 2006
      • 2823
      I'll say. What do you think he's gunna do run wires to his trunk through his door?
      OP you meant the door sills, just pull up on them. The plastic clips will pop out. If they break buy some new ones. Run the wires under the carpets under the door sill you will see the rest of the chassis wiring bundles there as well. Pop the rear seat up and find a hole in the trunk wall to fit the wires through.
      It ain't hard.
      '89 Alpine S52 with goodies
      • MattM
        • Apr 2009
        • 931
        run them down under the carpet under the center console, under the rear seat, and out with the battery cable into the trunk... its WAY easier. I did this when i installed an inverter in my car. wanted the plugs up at the front, inverter in the back
        Full Build Thread Here
